LOADJG
Subcase Information Entry Used in the Subcase Information section to select a load set to be applied to joints which are defined via the JOINTG Bulk Data Entry.
LOADJG = option
| Argument | Options | Description |
| option | <SID> No default  |
- Only one LOADJG entry can be present for each subcase.
 - LOADJG is currently supported only for Axial, Inline, and Revolute joints.
