LOADCYH
Bulk Data Entry Used to define the loading by harmonics in cyclic symmetry analysis.
| LOADCYH | SID | S | HID | HTYPE | S1 | L1 | S2 | L2 | |
| + | S3 | L3 | etc. |
| LOADCYH | 12 | 1.0 | 11 | C | 2.5 | 23 | 1.0 | 11 |
| SID | Load identification number. No default (Integer > 0)  |
| S | Scale factor. 7 No default (Real)  |
| HID | Harmonic index. 3 This entry is valid only when HTYPE = C or S. No default (Integer ≥ 0)  |
| HTYPE | Flag for the harmonic type. 4
                                    5
 (Character or blank)  |
| Si | Scale factor. 7 No default (Real)  |
| Li | Load identification number.  May reference any of the loading entries, except accelerations (ACCEL/ACCEL1/ACCEL2). No default (Integer > 0)  |
- LOADCYH Bulk Data Entry can be referenced by LOAD in the Subcase Information section.
 - LOADCYH can share a same ID with other LOADCYN or LOADCYH Bulk Data Entries.
 - LOADCYH cannot
                        share a same ID with other load set bulk entries. The harmonic index
                            HID should be also specified by HARMONICS, and are supposed to be non-negative and
                        must be no greater than (NSEG is defined in the CYSYM Bulk Data Entry).
If NSEG is odd:
If NSEG is even:
 - When, HTYPE = GRAV and RFORCE, the loading refers to GRAV and RFORCE entries, respectively. In these cases, HID is not required since the harmonic loads for appropriate available harmonics (also specified by HARMONICS) will be generated automatically.
 - An arbitrary load
                             applied to the
                             segment of the structure (through
                            LOADCYN) can be decomposed as:
Where, is the harmonic index (HID).
HTYPE = C or S are load options that directly specify the above coefficients and of the harmonic, for the cosine and sine components, respectively.
If HTYPE is blank, the load will be applied to both C and S components.
 - LOADCYN can reference all types of loads including an SPCD that defines enforced displacement, velocity or acceleration values. The LOADADD Bulk Data Entry is not supported.
 - The loading defined by
                            LOADCYN is given by:Where,
- Load vector referenced through Li.
 - Number of load vectors.
 - In cyclic symmetry analysis, the specified coordinate system (CID field) on GRAV must be rectangular. The component parallel to the axis of cyclic symmetry would contribute to the zeroth harmonic and the components perpendicular to the axis would contribute to harmonic of the first order.
 - In cyclic symmetry analysis, the rotational vector of RFORCE must coincide with the axis of symmetry which results in a cyclic symmetric centrifugal loading.
 - Nonlinear implicit cyclic symmetry subcases do not allow non-cyclic symmetric loadings and behaviors due to theoretical restrictions. Therefore, the regular method of loadset definition is adopted, that is, to directly reference a loadset ID of either load collectors LOAD(ADD)/DLOAD or a set of loads.
