LATPRM
Bulk Data Entry Defines the parameters available for Lattice Optimization Control.
| LATPRM | PARAM1 | VAL1 | PARAM2 | VAL2 | PARAM3 | VAL3 | PARAM4 | VAL4 | |
| PARAM5 | VAL5 | etc |
| LATPRM | LATLB | CHECK | POROSITY | MED |
| PARAMi | Parameter name. See below for valid names. | |
| VALi | Parameter value. (Real, Integer, or Character)  |
- Some of the parameters may also be defined as separate entities in the I/O section of the deck, using the Previous (OS3.5) Input Format. Only one definition is allowed.
 - This card is represented as an opticontrols in HyperMesh.
 - For more information, refer to Lattice Structure Optimization in the User Guide.
