INVELJ
Bulk Data Entry Defines initial velocity of a joint in a multibody situation.
| INVELJ | SID | JID | JTYPE | VT | VR |
| INVELJ | 1 | 3 | REV | 10.0 |
| SID | Load set identification
                                    number. (Integer > 0)  |
| JID | Joint identification
| JTYPE | Joint type.
 No default  |
| VT | Translational
                                    velocity. Real, when JTYPE = TRANS  |
| VR | Rotational
                                    velocity. Real, when JTYPE = REV  |
