Bulk Data Entry Defines parameters that control connectivity and
        configuration checks for gap elements (CGAP and
        CGAPG). Most of these parameters also affect contact elements that are
        automatically created on CONTACT interfaces - see individual descriptions
        for details.
                            | (1) |
                            (2) |
                            (3) |
                            (4) |
                            (5) |
                            (6) |
                            (7) |
                            (8) |
                            (9) |
                            (10) |
                            | GAPPRM |
                            PARAM1 |
                            VAL1 |
                            PARAM2 |
                            VAL2 |
                            PARAM3 |
                            VAL3 |
                            PARAM4 |
                            VAL4 |
                            PARAM5 |
                            VAL5 |
                            etc. |
                            | (1) |
                            (2) |
                            (3) |
                            (4) |
                            (5) |
                            (6) |
                            (7) |
                            (8) |
                            (9) |
                            (10) |
                            | GAPPRM |
                            CKGPDIR |
                            -1 |
                            PRTSW |
                            1 |
                            CHKRUN |
                            1 |
                                | Field |
                                Contents |
                                SI Unit Example |
                                | PARAM# |
                                Name of
                                    parameter. |
                                | VAL# |
                                Value of
                                    parameter. |
            While textual values are recommended for clarity, their integer equivalents will also
                be read. The available parameters and their values are listed below (click the
                parameter name for parameter descriptions).
                        - Parameter
                        - Value
                        - GAPPRM, CHKRUN
                        - <NO, 0, YES, or
                                1>
                        - Default = NO
                        - GAPPRM, CKGPDIR
                        - <ERR, 2, WARN,
                                1, NO, 0,
                                REV, or 3>
                        - Default = ERR
                        - GAPPRM, ERRMSG
                        - <SHORT, 1, FULL,
                            or 2>
                        - Default = SHORT
                        - GAPPRM, GAPCMPL
                        - <NO, 0, YES,
                                1>
                        - Default = YES
                        - GAPPRM, GAPGPRJ
                        - <NORM, 1, SHORT,
                            or 2>
                        - Default = SHORT
                        - GAPPRM, GAPOFFS
                        - <YES, NO,
                            AUTO>
                        - Default = AUTO
                        - GAPPRM, GPCOINC
                        - <Real>
                        - Defaults
                                    - For GAP elements
                                    - 1.0e-04
                                    - For CONTACT elements:
                                    - Calculated automatically based on element size on the main
                                        face.
                        - GAPPRM, HMGAPST
                        - <NO, 0 YES,
                                1>
                        - Default = NO
                        - GAPPRM, PRTSW
                        - <NO, 0, YES,
                                1>
                        - Default = NO
            - The GAPPRM entry
                changes the default settings of control parameters for the gap elements connectivity
                and checks for configuration errors. None of the parameters of this entry are
                required.
            - The gap alignment check controlled by the
                default value of CKGPDIR = ERR applies correctly
                to the most typical situations wherein there is an initial opening between bodies A
                and B, and the gap element is used to enforce non-penetration condition. For cases
                of overlapping meshes (combined with a prescribed coordinate system), the
                    REV value is appropriate - it allows both aligned and reversed
                gap directions (respective to the gap axis defined by the prescribed system).
            - This card is represented as a control card
                in HyperMesh.
