FREQ1
Bulk Data Entry Defines a set of frequencies to be used in the solution of frequency response problems by specification of a starting frequency, frequency increment, and the number of increments desired.
| FREQ1 | SID | F1 | DF | NDF |
| FREQ1 | 6 | 2.9 | 0.5 | 13 |
| SID | Set identification
                                        number. No default (Integer > 0)  |
| F1 | First frequency in
                                        set. No default (Real ≥ 0)  |
| DF | Frequency
                                        increment. No default (Real > 0.0)  |
| NDF | Number of frequency
                                        increments. Default = 1 (Integer > 0)  |
- FREQ1 entries must be selected with the I/O Options or Subcase Information command FREQUENCY = SID.
 - The units for F1 and DF are cycles per unit time.
 - The frequencies defined by this entry are
                given by fi = F1
                + DF * (i -1)
where i = 1 to (NDF + 1).
 - All FREQi entries with
                    the same set identification numbers will be used. Duplicate frequencies will be
                    ignored.
                         and
                         are considered duplicated if:Where,
- DFREQ
 - User parameter with a default of 10-5 *
 - The maximum and minimum excitation frequencies of the combined FREQi entries
 - This card is represented as a load collector in HyperMesh.
