FATSEAM
Bulk Data Entry Used to define parameters and property identification data for Seam Weld Fatigue Analysis.
| FATSEAM | ID | WTYPE | REFEID | WLDSIDE | |||||
| PSHELL | PID1 | PID2 | etc | etc | etc | etc | PID7 | ||
| PID8 | PID9 | etc | |||||||
| ELSET | SETID1 | SETID2 | SETID3 | SETID4 | SETID5 | SETID6 | SETID7 | ||
| SETID8 | SETID9 | SETID10 | etc |
| ID | Each
                                        FATSEAM card must have a unique ID.  No default (Integer > 0)  |
| WTYPE | Weld type.
 No default  |
| REFEID | Reference element
                                    identification number. 3 Default = blank (Integer > 0)  |
| WLDSIDE | Weld side. 4
 (Integer)  |
| PSHELL | Indicates that the following property fields reference PSHELL entries. | |
| PIDi | Property identifier of
                                    weld elements. 1 No default (Integer > 0)  |
| ELSET | Indicates the following fields reference element SET IDs. | |
| SETIDi | Element SET ID of weld
- For the Volvo method
                        (METHOD=VOLVO on
                        FATPARM), the seam weld elements should be modeled with
                        CQUAD4 or CTRIA3 elements only that
                    reference PSHELL properties. CTRIA3
                    elements should only be used for corner or end closing. For the Volvo method,
                    both PSHELL and ELSET continuation lines
                    can be used to identify the weld elements. In the case of
                        ELSETs, they should only reference sets of
                        CQUAD4 or CTRIA3 elements that
                    reference PSHELLs.
For the Joint Line method (METHOD=JNTLINE on FATPARM), the seam weld elements should be modeled with PLOTEL elements only. The FATDEFnode numbering of the PLOTELs is not relevant and the PLOTEL elements only serve to identify the weld line and do not structurally affect the solution. For the Joint Line method, only the ELSET continuation line can be used to identify the set(s) of PLOTEL elements.
 - The FATDEF Bulk Data Entry may reference this identifier via the FATSEAM continuation line.
 - REFEID defaults are
                    governed by the following conditions:
- If WTYPE is set to T, REFEID is mandatory.
 - If WTYPE is set to L, and there are three shell plates joined at the weld line, then REFEID is mandatory.
 - WLDSIDE defaults
                    are governed by the following conditions:
- If WTYPE is set to T, GENERIC, and BUTT, then WLDSIDE is not mandatory.
 - If WTYPE is set to L and there are three shell plates joined at the weld line, then WLDSIDE is mandatory.
 - If WTYPE is set to L and there are two shell plates joined at the weld line, and WLDSIDE is blank, then the weld is located at the smaller angle side of the two shell plates.
 - If specified,
                        REFEID and WLDSIDE are used together
                    to identify the direction in which the weld exists. REFEID
                    identifies an element connected to the weld line, and WLDSIDE
                    identifies the direction of the weld, with respect to the element normal of the
                    element identified via REFEID. Figure 1 can help clarify how the weld
                    location is identified. EVALDIS is the evaluation distance
                    specified on the PFATSMW entry.
Figure 1. L Fillet Joint Example (WTYPE=L)
