Bulk Data Entry Used to assign property ID to elements in
            DMIG.
                            | (1) |
                            (2) |
                            (3) |
                            (4) |
                            (5) |
                            (6) |
                            (7) |
                            (8) |
                            (9) |
                            (10) |
                            | EL2PROP |
                            ID |
                            ELSETID |
                            PTYPE |
                            PROPID |
                            ELSETID |
                            PTYPE |
                            PROPID |
                            ELSETID |
                            PTYPE |
                            PROPID |
                            ELSETID |
                            PTYPE |
                            PROPID |
                            etc |
        Alternate Format
                            | (1) |
                            (2) |
                            (3) |
                            (4) |
                            (5) |
                            (6) |
                            (7) |
                            (8) |
                            (9) |
                            (10) |
                            | EL2PROP |
                            ID |
                            ALTER |
                            PROPID |
                            ELSETID |
                            ELSETID |
                            ELSETID |
                            ELSETID |
                            ELSETID |
                            ELSETID |
                            ELSETID |
                            ELSETID |
                            ELSETID |
                            etc |
                            etc |
                            PROPID |
                            ELSETID |
                            ELSETID |
                            ELSETID |
                            ELSETID |
                            ELSETID |
                            ELSETID |
                            ELSETID |
                            ELSETID |
                            ELSETID |
                            etc |
                            etc |
                            | (1) |
                            (2) |
                            (3) |
                            (4) |
                            (5) |
                            (6) |
                            (7) |
                            (8) |
                            (9) |
                            (10) |
                            | EL2PROP |
                            7 |
                            8 |
                            PSHELL |
                            3 |
        Alternate Format Example
                            | (1) |
                            (2) |
                            (3) |
                            (4) |
                            (5) |
                            (6) |
                            (7) |
                            (8) |
                            (9) |
                            (10) |
                            | EL2PROP |
                            7 |
                            ALTER |
                            3 |
                            8 |
                            2 |
                            | Field |
                            Contents |
                            SI Unit Example |
                            | ID |
                            Identification number of
                                    EL2PROP. No default (Integer >
                                0)  |
                            | ALTER |
                            ALTER
                                flag indicating the alternate format is being used. |
                            | ELSETID |
                            Element set identification
                                    number. No default (Integer > 0)  |
                            | PTYPE |
                            (Optional) Property
                                    type.
                                        - PSHELL
                                        - PSOLID
                            | PROPID |
                            Property identification
            - This EL2PROP Bulk
                Data Entry can be used to assign Property ID's' to Element sets.
            - The ID field is only
                used by HyperMesh. When ECHO entry is
                present in the model, all EL2PROP entries will be combined into
                one EL2PROP entry with an internally generated
                    ID. The ID of the
                    EL2PROP entries are not used in OptiStruct.
