EIGRD
Bulk Data Entry Defines data required to perform eigenvalue extraction using the Lapack-based dense solver.
| EIGRD | SID | V1 | V2 | ND | NORM |
| EIGRD | 0.1 | 3.2 | 10 |
| SID | Unique set identification number. No default (Integer > 0)  |
| V1,V2 | For
                                                  vibration analysis: Frequency range of
                                                  interest. Default = blank (V1 < V2, Real, or blank)  |
| ND | Number of roots desired.  No default (Integer > 0 or blank)  |
| NORM | Method used for eigenvector normalization.
 Default = MASS for normal modes analysis  |
- For CMS residual runs, EIGRD is suitable for models with 20,000 degrees of freedom or lower.
