EDGEBH
Bulk Data Entry Defines geometry and restraining force per unit length for an edge blank holder in a one-step stamping simulation.
| EDGEBH | EID | S1 | T2 | S2 | T2 | BFORCE | BSID |
| EDGEBH | 6 | -1.0 | 1.0 | 1.0 | 1.0 | 100.0 | 5 |
| EID | Element identification number. No default (Integer > 0)  |
| S1, T1 | Parametric entry points for the line. No default (Real; | S1, T1 | ≤ 1.0)  |
| S2, T2 | Parametric exit points for the line. No default (Real; | S2, T2 | ≤ 1.0)  |
| BFORCE | Blank holder restraining force. No default (Real)  |
| BSID | Blank holder set identifier for retrieving the
                                                  input file back to HyperForm. Not used by the
                                                  solver. No default (Integer > 0)  |
- This entry is only valid with an @ HyperForm statement in the first line of the input file.
