DSA
I/O Options and Subcase Information Entry The DSA command can be used in the I/O Options section to request Design Sensitivity Analysis results in a Frequency Response Analysis.
DSA (TYPE, PEAKOUT, PROPERTY) = SID
Examples
DSA(DISP,PROPERTY)=12
DSA(VELO,PEAKOUT)=45
DSA(ACCE,PEAKOUT,PROPERTY)=23
| Argument | Options | Description |
| TYPE | <DISP, PRES, VELO, ACCE, ERP> | Available options:
| PEAKOUT | Default = blank | If PEAKOUT is present inside the parentheses of the DSA entry, the filtered frequencies from the PEAKOUT card will be considered for DSA results. |
| PROPERTY | Default = blank | If
                                    PROPERTY is present: This indicates that
                                design sensitivities represent the change in design response due to
                                a change in design properties (instead of design variables). If PROPERTY is not present: This indicates that design sensitivities represent the change in design response due to a change in design variables.  |
| SID/ALL | <SID, ALL> |
- If multiple instances of the DSA request are defined within a subcase or outside all the subcases, then the union of all these instances will be used for the output.
 - If the input deck does not contain any optimization data (apart from DESVARs), a MASS objective function is automatically created along with responses and constraints corresponding to the DSA request. If the input deck contains a valid optimization setup, then it is augmented with the DSA request.
 - In the H3D file, the "SCALE" value is only printed when the PROPERTY argument is not present within the parentheses of the DSA entry. The sensitivities are pre-scaled when the PROPERTY argument is present in the DSA entry, so the scaling factor is not required in the H3D file.
 - OUTPUT, H3DSENS can be
                    used to include (or exclude) user-defined responses in the
                        DSA output. DSA output (including user-defined responses)
                    is limited to displacement, velocity, acceleration, acoustic pressure, ERP and
                    powerflow DRESP1 responses.
Output Sensitivities requested via the DSA output request (responses are automatically defined) Sensitivities output from a complete Optimization setup (User-defined responses via DRESP1) OUTPUT, H3DSENS, USER Yes Yes OUTPUT, H3DSENS, NOUSER Yes No  - Design variables and their corresponding design properties must be defined in the input deck if sensitivity output is requested through the DSA entry.
 - DSA output for ERP is available for ALL panels. Set ID (SID) cannot be used and is ignored, if specified.
