DRAPE
Bulk Data Entry Defines the draping data for plies used in ply-based composite definition.
| DRAPE | ID | ||||||||
| DTYPE1 | DID1 | T1 | THETA1 | ||||||
| DTYPE2 | DID2 | T2 | THETA2 | ||||||
| etc |
| ID | Unique draping
                                identification number. No default (Integer > 0)  |
| DTYPE# | Entity type.
 No default  |
| DID# | Entity number. Must refer
                                to an element (for ELEM) or SET
                                (for SET) Bulk Data Entry. Must be blank for
                                    ALL. No default (Integer > 0 or blank)  |
| T# | Thinning factor. Default = 1.0 (Real or blank)  |
| THETA# | Angle variation. Default = 0.0 (Real or blank)  |
