DLINK
Bulk Data Entry Defines a link between one design variable and one or more other design variables.
| DLINK | ID | DDVID | C0 | CMULT | IDV1 | C | IDV2 | C | |
| IDV3 | C | etc. |
| DLINK | 55 | 3 | 0.2 | 0.45 | 5 | 2.0 | 10 | 5.5 | |
| 15 | -3.0 |
| ID | Unique
                                    DLINK identification number. (Integer > 0)  |
| DDVID | Dependent Design Variable
| C0 | Constant. Default = 0.0 (Real)  |
| CMULT | Constant
                                    multiplier. Default = 1.0 (Real)  |
| IDVi | Independent Design
                                Variable identification number. Can occur on the same
                                    DLINK entry only once. (Integer > 0)  |
| Ci | Coefficient multiplier for
                                    IDVi. (Real)  |
- DLINK defines the
                    relationship.
This capability allows physical and non-physical design variables to be related such as shell thickness and interpolating functions.
 - CMULT and Ci can be used together to provide a simple means of scaling.
 - This card is represented as an optimization design variable link in HyperMesh.
