DELAY
Bulk Data Entry Defines the time delay term in the equations of the dynamic loading function. DELAY is used in conjunction with RLOAD1, RLOAD2, TLOAD1, and TLOAD2 entries.
| DELAY | SID | P | C | T1 | P | C | T2 |
| DELAY | 3 | 64 | 2 | 5.7 | 65 | 2 | 5.7 |
| SID | Identification
                                    number. No default (Integer > 0)  |
| P, P | Grid or scalar point
                                identification number. No default (Integer > 0)  |
| C, C | Component number. No default (Integer 1 through 6, or 0 for scalar points)  |
| T1, T2 | Time delay term,
        , for designated point and component. No default (Real)  |
- One or two dynamic load time delays may be defined on a single entry.
 - SID must also be specified on a RLOAD1, RLOAD2, TLOAD1, or TLOAD2 entry. See those entry descriptions for the formulae that define the manner in which the time delay term, , is used.
 - A DAREA entry should be used to define a load at P# and C#. This condition is not required, if SPCD is applied to these degrees of freedom.
 - When the SPSYNTAX setting on the SYSSETTING I/O Option is set to CHECK (default) or STRICT, it is required for grid/component pairs (G#/C#) that the component be 0 or blank when the grid reference is a scalar point (SPOINT), and that the component be ≥ 1 when the grid reference is a structural grid point (GRID). When SPSYNTAX is set to MIXED, it is allowed for grid/component pairs (G#/C#) that the grid reference be either a scalar point (SPOINT) or a structural grid point (GRID) when the component is 0, 1 or blank; interpreting all of these as 0 for scalar points and as 1 for structural grids. When the component is greater than 1, the grid reference must always be a structural grid (GRID).
 - This card is represented as a constraint load in HyperMesh.
