Forced Convection for Linear Steady-State Heat Transfer is available via Darcy Flow
        analysis.
            Darcy Flow Analysis is currently only supported for steady-state heat transfer
                analysis. Forced convection applications include cooling solutions for electric
                motors, machine tools (casting, forming), heat exchangers, HVAC systems, and cooling
                for electronic devices including PCBs. Additionally, Topology Optimization is
                available for steady-state heat transfer with Darcy flow analysis. The topology
                optimization considers the effect of forced convection for cooling in conjunction
                with structural steady-state heat transfer analysis. Topology optimization can help
                optimize cooling channel structures and placement for a wide range of
                applications.
            The flow solution is described by:
            Where,
                        - Permeability matrix
                        - Nodal pressure in the structure
                        - Pressure load at the inlet
            The fluid flow analysis is solved using Darcy’s Law, which describes the flow of a
                fluid through a porous medium:
            Where,
                        - Fluid velocity
                        - Fluid permeability (this is different from thermal conductivity,
                            represented by
                        - Fluid dynamic viscosity
                        - Pressure differential
            The equation can be rewritten as:
            Where,
                        - Element fluid velocity
                        - Differential of the shape function
                        - Nodal pressure in the element (which is sourced from the flow
                            solution)
            The thermal steady-state heat transfer solution is represented by:
            Where,
                        - Conductivity Matrix:
                        - Convection Matrix (which includes flow velocity
                                 from Darcy's Law):
Where,
                                        - Thermal load vector
                                        - Nodal temperature matrix
                                        - Enhanced shape function
                                        - Total number of elements
                                        - Density
                                        - Thermal conductivity (this is different from fluid
                                            permeability, Kappa, represented by
                                        - Specific heat capacity
                                        - Element flow velocity from Darcy’s Law
            The thermal steady-state solution incorporates forced convection via the Convection
                Matrix. A topology design space can be defined for a steady-state heat transfer
                subcase to run the optimization solution which accounts for the forced convection
                via Darcy flow.
