Bulk Data Entry Used to list the grids that lie on the axis of symmetry, in cyclic symmetry
        analysis.
        Format 1
                                | (1) |
                                (2) |
                                (3) |
                                (4) |
                                (5) |
                                (6) |
                                (7) |
                                (8) |
                                (9) |
                                (10) |
                                | CYAX |
                                GID1 |
                                GID2 |
                                GID3 |
                                GID4 |
                                GID5 |
                                GID6 |
                                GID7 |
                                GID8 |
                                GID9 |
                                GID10 |
                                etc. |
        Format 2
                                | (1) |
                                (2) |
                                (3) |
                                (4) |
                                (5) |
                                (6) |
                                (7) |
                                (8) |
                                (9) |
                                (10) |
                                | CYAX |
                                GID1 |
                                GID2 |
                                GID3 |
                                THRU |
                                GID5 |
                                GID6 |
                                GID7 |
                                GID8 |
                                GID9 |
                                GID10 |
                                etc. |
        Example 1
                                | (1) |
                                (2) |
                                (3) |
                                (4) |
                                (5) |
                                (6) |
                                (7) |
                                (8) |
                                (9) |
                                (10) |
                                | CYAX |
                                101 |
                                27 |
                                50 |
                                51 |
                                52 |
                                53 |
                                54 |
                                55 |
                                122 |
        Example 2
                                | (1) |
                                (2) |
                                (3) |
                                (4) |
                                (5) |
                                (6) |
                                (7) |
                                (8) |
                                (9) |
                                (10) |
                                | CYAX |
                                102 |
                                27 |
                                50 |
                                THRU |
                                55 |
                                122 |
                                | Field |
                                Contents |
                                SI Unit Example |
                                | GIDi |
                                Unique grid point identification number. No default
                                        (Integer > 0)  |
                    - Grid points on the axis of symmetry
                        should not be defined on the CYJOIN entry.
                    - The displacement coordinate system
                            (CD field on the GRID
                        entry) for a grid on CYAX must be rectangular. The Z-axis
                        in this coordinate system must coincide with the axis of symmetry for the
                        model.
                    - Grid points on
                            CYAX may be constrained by SPCs, but not by MPCs. If
                        all components are constrained by SPC, the grid point will be internally
                        ignored from the CYAX list.
                    - When 3 or more cyclic symmetric
                        segments (defined by NSEG field on the CYSYM entry) are involved, then any SPC to be
                        applied to the grids on CYAX should satisfy the following
                            rule:
                            - Both components 1 and 2 should be constrained, otherwise neither of
                                them should be constrained. The same rule applies to components 4
                                and 5.
                            - There is no restriction to components 3 and 6.
                    - By default, the axis of symmetry is
                        defined by the first grid pair on the CYJOIN entry, while
                        the CYAX entry does not define the axis of symmetry for
                        cyclic symmetry analysis. Adding PARAM, AXCYSYM, YES allows the axis of symmetry to be defined
                        according to the grids listed on the CYAX entry, instead
                        of using the grids from the CYJOIN entry, and the rules
                        described in Comment 2 still apply.
