CTUBE
Bulk Data Entry Defines a tension-compression-torsion element (TUBE) of the structural model.
| CTUBE | EID | PID | G1 | G2 |
| CTUBE | 12 | 13 | 21 | 23 |
| EID | Unique element identification
                    number. (Integer > 0)  |
| PID | A PTUBE property entry
                                identification number. (Default = EID, Integer > 0)  |
| G1, G2 | Grid point identification
                                numbers of connection points. (Integer > 0; G1 ≠ G2)  |
- Only one TUBE element may be defined on a single entry.
 - CTUBE data is converted to CROD data as it is read. PTUBE data is converted into PROD data.
 - This card is represented as a rod element in HyperMesh.
