Bulk Data Entry Defines a 1st order, four-noded element used in the
        definition of arbitrary beam cross-sections.
        | (1) |
        (2) |
        (3) |
        (4) |
        (5) |
        (6) |
        (7) |
        (8) |
        (9) |
        (10) |
| CSEC4 |
EID |
PID |
G1 |
G2 |
G3 |
G4 |
                          | (1) |
                          (2) |
                          (3) |
                          (4) |
                          (5) |
                          (6) |
                          (7) |
                          (8) |
                          (9) |
                          (10) |
                            | CSEC4 |
                            10 |
                            100 |
                            3 |
                            4 |
                            5 |
                            6 |
                            | Field |
                            Contents |
                            SI Unit Example |
                            | EID |
                            Element identification
                                    number. No default (Integer > 0)  |
                            | PID |
                            A PSEC section property entry identification
                                    number. Default = EID (Integer >
                                0)  |
                            | G# |
                            GRIDS section grid points identification
            - Element identification numbers within a
                    section definition must be unique with respect to all other element
                    identification numbers within the same section definition.
            - This entry is only valid when it appears
                    between the BEGIN and END
                statements.
