CORD2R
Bulk Data Entry Defines a rectangular coordinate system by using three grid points.
Attention: Valid for Implicit
                    and Explicit Analysis
            The coordinates of the three non-collinear grid points are used to uniquely define the coordinate system.The first point is the origin, the second lies on the Z-axis, and the third lies in the X-Z plane.
| CORD2R | CID | RID | A | A | A | B | B | B | |
| C | C | C |
| CORD2R | 3 | -2.9 | 1.0 | 0.0 | 3.6 | 0.0 | 1.0 | ||
| 5.2 | 1.0 | -2.9 |
| CID | Unique coordinate system
                    identification.
 (Integer > 0 or <String>)  |
| RID | Identification number of a reference
                    coordinate system that is defined independently from this coordinate
                    system.6 Default = 0 (Integer ≥ 0)  |
| A, A, A, B, B, B, C, C, C | Coordinates of three points in the
                    reference coordinate system (RID). If RID
                    is blank or 0, the reference coordinate system is the default basic coordinate
                    system. (Real)  |
- The three points (A1, A2, A3), (B, B, B), (C, C, C) must be unique and non-collinear. Non-collinearity is checked by the geometry processor.
 - Coordinate system identification numbers on all CORD1R, CORD1C, CORD1S, CORD2R, CORD2C, CORD2S, CORD3R, and CORD4R entries must all be unique.
 - A duplicate identification number is allowed if the CID and GID are identical and the coordinates are within the value set by PARAM,DUPTOL. See Bulk Data Guidelines for further information.
 - The location of a grid point (P) in this rectangular coordinate system is given by (X, Y, and Z). See Figure 1.
 - The displacement coordinate directions at P are (Ux, Uy, and Uz). See Figure 1.
 - The reference coordinate system (RID) should be independently defined or left blank. If blank (or 0), the reference coordinate system is the default basic coordinate system. In such cases, A, B and C are defined with respect to the basic coordinate system.
 - String based labels allow for easier visual identification of coordinate systems, including when being referenced by other cards. Currently, coordinate systems with string IDs can be referenced only by JOINTG elements. For more details, refer to String Label Based Input File in the Bulk Data Input File.
 - This card is represented as a system in HyperMesh.
