CMSPDPM
Bulk Data Entry Defines a spring damper element without reference to a property entry for multibody solution sequence based on marker.
| CMSPDPM | EID | K | M1 | M2 | B | L | PF | TYPE |
| CMSPDPM | 3 | 34.5 | 223 | 324 | 0.0 | 1.0 | TRANS |
| EID | Unique element
                                identification number. (Integer > 0)  |
| K | Stiffness value. Default = 0.0 (Real or blank)  |
| M1, M2 | Marker identification
| B | Damping value. Default = 0.0 (Real or blank)  |
| L | Unstretched length of
                                spring damper. Default = 0 (Real ≥ 0.0 or blank)  |
| PF | Preload force. Default = 0 (Real or blank)  |
| TYPE | Type.
- The spring damper force is along the line segment connecting the marker M1 and M2.
 - The positive preload force is a stretching force.
 - This card is represented as a spring element in HyperMesh.
