CMETHOD
Subcase Information Entry The CMETHOD command can be used to select the method for complex eigenvalue extraction.
CMETHOD = option
| Argument | Options | Description |
| option | <SID> No default  |
- Only one CMETHOD entry can be defined in a subcase.
 - A CMETHOD entry is required for Complex Eigenvalue Analysis.
 - If present above the first subcase, it is applied to all complex eigenvalue subcases.
