CMASS3
Bulk Data Entry Defines a scalar mass element that is connected only to scalar points.
| CMASS3 | EID | PID | S1 | S2 |
| CMASS3 | 13 | 42 | 62 |
| EID | Unique element
                                identification number. No default (Integer > 0) | |
| PID | A PMASS property identification number.
 Default = EID (Integer > 0 or <String>) | |
| S1, S2 | Scalar point
                                identification numbers. S1 or S2, but not both, may be blank or zero, indicating a constrained coordinate. Default = 0 (Integer ≥ 0; S1 ≠ S2) |
- Only one scalar mass element may be defined on a single entry.
- A scalar point specified on this entry does not need to be defined on a SPOINT Bulk Data Entry.
- Scalar mass elements are ignored in heat transfer analysis.
- String based labels allow for easier visual identification of properties, when being referenced by the elements cards. For more details, refer to String Label Based Input File in the Bulk Data Input File.
- This card is represented as a spring or mass element in HyperMesh.
