CGASK12
Bulk Data Entry Defines the connections of the GASK12 solid gasket element.
| CGASK12 | EID | PID | G1 | G2 | G3 | G4 | G5 | G6 | |
| G7 | G8 | G9 | G10 | G11 | G | ||||
| CORDM | CID |
| CGASK12 | 71 | 4 | 3 | 4 | 5 | 6 | 7 | 8 | |
| 9 | 10 | 11 | 12 | 13 | 14 |
| EID | Unique element identification
                  number. No default (Integer > 0)  |
| PID | Identification number of a PGASK property entry. Default = EID (Integer > 0)  |
| G# | Grid point identification number of
                connection points. No default (Integer > 0)  |
| CORDM | Flag indicating that the following field references the material coordinate system. | |
| CID | Material coordinate system
                identification number. Default = 0 (Integer ≥ -1)  |
- Corner grid points G1, G2, and
            G3 must be given in consecutive order at the bottom face of the
          gasket element. Corner grid points G4, G5, and
            G6 must be on the top face with G4 opposite
            G1, G5 opposite G2, and so
            on.Edge grid points G7, G8, and G9 must be given in consecutive order at the bottom face of the gasket element. Edge grid points G10, G11, and G must be on the top face with G10 opposite G7, G11 opposite G8, and so on.
 - If the user-defined node numbering on the bottom and top faces is reversed as compared to the sequence shown above, the nodes are renumbered to produce right-handed orientation of numbering. This is accomplished by swapping nodes G1 with G3, and G4 with G6. In such cases, the element local coordinate system will be built on the renumbered node sequence.
 - The
        element coordinate system for the CGASK12 element is defined below.
The local 3-direction (the gasket material thickness direction in default) is defined as the simple average of the unit normal directions on the top and bottom surfaces of the element. After the local 3-direction is defined, a local 1-2 plane is generated accordingly.
Then, the local 1-direction and 2-direction are defined as follows: Project the basic x-axis onto the local 1-2 plane, and set it to be the default local 1-direction. If the basic x-axis is within 0.1° difference as the local 3-direction, project the basic z-axis onto the local 1-2 plane and set it to be the local 1-direction. The local 2-direction is determined then.
 - The gasket material coordinate system is the same as the element coordinate system in default and can be defined as a prescribed system through PGASK entry.
 - This card is represented as a gask12 element in HyperMesh.
