CDAMP4
Bulk Data Entry Defines a scalar damper element that is connected only to scalar points and is without reference to a material or property entry.
| CDAMP4 | EID | B | S1 | S2 |
| CDAMP4 | 16 | -2.6 | 4 | 9 |
| EID | Unique element
                                identification number. No default (Integer > 0)  |
| B | Scalar damper value. No default (Real)  |
| S1, S2 | Scalar point
                                identification numbers. Default = 0 (Integer ≥ 0; S1 ≠ S2)  |
- S1 or S2, but not both, may be blank or zero, indicating a constrained coordinate.
 - This single entry completely defines the element since no material or geometric properties are required.
 - Only one scalar damper element may be defined on a single entry.
 - A scalar point specified on this entry does not need to be defined on a SPOINT Bulk Data Entry.
 - Scalar damper elements are ignored in heat transfer analysis.
 - This card is represented as a spring or mass element in HyperMesh.
