CACINF4
Bulk Data Entry Defines an Acoustic Infinite Element with a quadrilateral base.
| CACINF4 | EID | PID | G1 | G2 | G3 | G4 |
| CACINF4 | 7 | 1 | 123 | 225 | 9991 | 1001 |
| EID | Unique element
                                identification number. No default (Integer > 0)  |
| PID | Identification number of a
                                    PACINF property entry. No default (Integer > 0)  |
| G1, G2, G3, G4 | Grid point identification
                                numbers of element base connection points. No default (Integer > 0)  |
- The element should be connected to acoustic grid points.
 - The element normal is defined by the right-hand rule. If the normal does not point to the exterior domain, an error message will be issued.
