BNDFIX
Bulk Data Entry Defines the degrees-of-freedom to be fixed during DMIG generation using CMSMETH card.
| BNDFIX | GID1 | IC | GID2 | IC | GID3 | IC |
| BNDFIX | 1220 | 12345 |
| GIDi | Grid of scalar point
                                identification numbers. No default (Integer > 0)  |
| ICi | Component numbers. No default (Integer > 0)  |
- BNDFIX and BSET are equivalent.
 - ASET, BNDFIX and BNDFREE; all three are not allowed in the same deck.
 - If BNDFREE and ASET are present, the DOFs associated with ASET would be in BNDFIX; except the DOF assigned to BNDFREE.
 - If BNDFIX and ASET are present, the DOFs associated with ASET would be in BNDFREE; except the DOF assigned to BNDFIX.
