I/O Options EntryDefines an assembly of parts which are included in the global model.
                            | (1) |
                            (2) |
                            (3) |
                            (4) |
                            (5) |
                            (6) |
                            (7) |
                            (8) |
                            (9) |
                            (10) |
                            | ASSEMBLY |
                            GLOBNAME |
                            | (1) |
                            (2) |
                            (3) |
                            (4) |
                            (5) |
                            (6) |
                            (7) |
                            (8) |
                            (9) |
                            (10) |
                            | ASSEMBLY |
                            Global1 |
                            | Field |
                            Contents |
                            SI Unit Example |
                            | ASSEMBLY |
                            Activates the creation of
                                an assembly of parts. |
                            | GLOBNAME |
                            Name of the assembly
                                should match the name of the global part in the Bulk Data
                                    section. (Character String)  |
            - If an ASSEMBLY entry is
                input in the model, then a minimum of one INSTANCE I/O
                Options Entry should be present.
            - Only one ASSEMBLY entry
                can be present in a model.
 - When
                    ASSEMBLY entry is present, the reading of the Bulk Data
                section is different.
                    - Without ASSEMBLY entry, each part defined in the input
                        deck is used in the model.
                    - When ASSEMBLY/INSTANCE entries are
                        present, each part named on ASSEMBLY and
                            INSTANCE entries are used, potentially multiple
                        times, and parts with unknown names (which are not listed on any
                            ASSEMBLY/INSTANCE cards) are
                        skipped.
