Fatigue Input/Output
Fatigue input for Spot Weld Fatigue Analysis can be divided into the following categories:
Fatigue Element Identification
- CHEXA elements
                                                  can be used to define the weld element for Spot
                                                  Weld Fatigue Analysis. In such cases, the grid
                                                  point forces are resolved into corresponding
                                                  forces and moments at the face centers of the
                                                  opposing faces connected to the shells. The faces
                                                  of the CHEXA element attached
                                                  to the sheets should always consist of grid points
                                                  in the following order.
Figure 1. Faces of the CHEXA that Should be Used as Connection Faces with Shells for Spot Weld Fatigue
Additionally, the default weld element diameter of the CHEXA element for spot weld fatigue is equal to two times the smallest distance from the attachment face centroid to the edges.
Fatigue Parameters
Fatigue Material
Fatigue Loads
- Similar to regular fatigue analysis, .
Output
Output for Spot Weld Fatigue Analysis is provided similar to regular Fatigue Analysis results. . The damage calculation .
