Baseline correction can be applied to correct the acceleration record to avoid
        displacement shift.
            When acceleration is applied as input via SPCD, the integration of
                displacement results may diverge at the last point of simulation. Baseline
                correction can be used to correct the acceleration input. The BASELIN Subcase and BASELIN
                Bulk Data Entry pair can be used to apply baseline correction.
            There are two methods by which Baseline correction can be applied. For both cases,
                the acceleration load is corrected by fitting the load to a polynomial with
                coefficients
                    , and
        Acceleration Method (METHOD=ACCE on BASELIN Bulk Data)
            The baseline correction to the acceleration load is calculated as:
            The corrected acceleration load is:
            The coefficients of the polynomial are evaluated by minimizing the square of the
                corrected acceleration load.
            Where,
                                , and
                        - Coefficients of the polynomial, which are unknowns to be calculated from
                            the above minimization functions.
                        - Function of polynomial coefficients.
                        - Input acceleration load.
                        - Baseline correction of the acceleration.
                        - Corrected acceleration after baseline correction.
                        - Time associated with each acceleration data point in the record.
                        - Total number of acceleration data points in the record (points on
                                TABLED# entry referenced on
                                TLOAD1 entry).
        Velocity Method (METHOD=VELO on BASELIN Bulk Data)
            The corrected velocity is:
            The coefficients of the polynomial are evaluated by minimizing the integration of
                square of the corrected velocity load.
            Where,
                                , and
                        - Velocity load.
                        - Corrected velocity after baseline correction.
                                 and
                        - Initial and final total time.
                        - For both continuation subcases or independent subcases, the baseline
                            correction calculation is conducted for each subcase, and separate
                                , and
                                 coefficients are calculated for each
                            subcase for baseline correction. In the case of continuation subcases,
                            the values of
                                 and
                                 used in the calculation are still the
                            total time.
