I/O Options and Subcase Information
                    Entry Used in the I/O Options section or in frequency response (direct and modal) subcases to
        request acoustic power radiated across a panel for Infinite Elements and Adaptive Perfectly
        Matched Layer (APML).
            ACPOWER (format) = option
                            | Argument |
                            Options |
                            Description |
                            | format |
                            <H3D, PUNCH, blank> |
                                        - H3D
                                        - Results are output in Hyper3D format (.h3d file).
                                        - PUNCH
                                        - Results are output in Punch format (.pch file).
                                        - Blank (Default)
                                        - Results are output in all active formats for which the
                                            result is available.
                            | option |
                            <YES, ALL,
                        NO, NONE> |
                                        - YES, ALL (Default), blank
                                        - The acoustic power is computed for all panels defined by
                                                PANELG with
                                                ACPOWER type in the Bulk section.
                                                1
                                        - NO,
                    NONE
                                        - Acoustic Power is not output.
                    - The result is output for every
                            PANELG entry whose type is
                        ACPOWER. In this case, PANELG also
                        accommodates a SURF entry.
                    - Acoustic Power results are available for Infinite Elements and Adaptive
                        Perfectly Matched Layer (APML). It is supported for both H3D and PUNCH
                        formats.
                    - Multiple formats are allowed on the
                        same entry; these should be comma-separated. If a format is not specified,
                        this output control applies to all formats defined by the
                            OUTPUT command, for which the result is
                        available.
                    - Multiple instances of this card are
                        allowed; if instances are conflicting, the last instance dominates.
                    - The acoustic power is calculated
                        using the surface integral of the real part (
                            ) of acoustic intensity
                            . Where,
                                - Surface area of the panel
                                - Local normal of the surface
The expression for acoustic intensity is related to the nodal
                            pressure (
                                ) and the complex conjugate of the
                            particle velocity (
                                ), given by:
                    - The calculation of
                            ACPOWER in decibels (dB) is performed using the
                            PARAM, ACPREFDB, for which the following equation is
                        used. ACPREFDB is the reference value of the power. This
                        output is currently available only in PUNCH format.
Where,
                                    - Acoustic power in decibels.
                                    - Reference acoustic power value specified using
                                            PARAM,ACPREFDB.
