Model.ME_ModulePrototypeInstanceCreateByID#
- Model.ME_ModulePrototypeInstanceCreateByID(parent_proto_part_entity, child_proto_part_entity, name, options)#
Create a module instance (part or part assembly) with a given pair of parent and child module prototype IDs.
- Parameters:
parent_proto_part_entity (Entity) – The object describing the entity.
child_proto_part_entity (Entity) – The object describing the entity.
name (hwString) – The name of the module instance to create.
options (hwString) –
Optional list of inputs passed as a comma separated string.
matrix: a list of 16 double values which describe the relative 4×4 matrix.
