Model.setreplacereportshowgui#
- Model.setreplacereportshowgui(option)#
This function is used to set in HM database to display the replace report about the affected entities by the mesh change in automesh panel.
If you pick the “update FE/part-replace” (currently available with env AUTOMESH_UPDATE_FE set to 1). These affected entities will be displayed in the browser as shown in example below, after user commits (after “return” button click) mesh change.
- Parameters:
option (int) –
0: no replace report GUI after you commit mesh change in automesh panel
1: shows the report in Replace browser of the solver entities that are affected by the mesh change in automesh panel
