Model.setgraphictranslation#
- Model.setgraphictranslation(entity, x, y, z)#
Graphically translates the specified entity. Currently only supported for FE inside of components.
- Parameters:
entity (Entity) – The object describing the entity.
x (double) – The x value of the graphic translation. A value of 0 indicates no translation.
y (double) – The y value of the graphic translation. A value of 0 indicates no translation.
z (double) – The z value of the graphic translation. A value of 0 indicates no translation.
Example#
Translate graphically the element with ID 3 along 50 units in the x-axis#import hm import hm.entities as ent model = hm.Model() model.setgraphictranslation(entity=ent.Element(model, 3), x=50.0, y=0, z=0)
