Model.hm_tabletomark#
Model.hm_tabletomark(tableName)#
Appends the entity IDs stored in table_name to collection mark_id. Valid mark_ids are 1 and 2. Tables are not stored within a database (.hm file). When the current model is deleted or a new model is loaded, all tables are cleared. If a table contains an entity that is subsequently deleted, the entity is removed from the table. Renumbering does not modify the entity IDs stored in the table.
Parameters:
tableName (hwString) – nan
Example#
Put the elements from table elem_table on element collection with ID 1#
import hm
import hm.entities as ent
model = hm.Model()
model.hm_tabletomark(tableName="elem_table")
