Model.hf_TrimBinderOrAddendumWithAddDbeadDbar#
- Model.hf_TrimBinderOrAddendumWithAddDbeadDbar(collection_surf, collection_line)#
- Trims the current die module binder or addendum with the current addendum drawbar/bead FL.
- If an input is not specified, the binder and FL are recognized automatically and trims the
current die module binder with the current addendum FL. If the surface mark is empty, it trims the current die module binder with the line contained into the line mark (trim binder with drawbar/bead).
- If the surface mark is full, it trims the addendum surface contained in the mark with the
line contained into the line mark (trim addendum with drawbar).
- Parameters:
collection_surf (Collection) – The collection containing the entities.
collection_line (Collection) – The collection containing the entities.
