Model.hf_TranslateBinderSurf#
- Model.hf_TranslateBinderSurf(plane_normal, plane_base, distance)#
- Translates the binder along an axis. The direction of translation is given by
- the plane/vector plane and the magnitude of translation is given by
distance.
- Parameters:
plane_normal (hwTriple) – The hwTriple object defining the plane normal components. User can also supply a Python list of three doubles.
plane_base (hwTriple) – The hwTriple object defining the base point components of the plane. User can also supply a Python list of three doubles.
distance (double) – Translation distance.
