Model.hf_RotateBinderSurf#
Model.hf_RotateBinderSurf(plane_normal, plane_base, angle)#
Rotates the binder around an axis. The axis of rotation is given by the
plane/vector plane and the magnitude of rotation is given by.
Parameters:
  • plane_normal (hwTriple) – The hwTriple object defining the plane normal components. User can also supply a Python list of three doubles.
  • plane_base (hwTriple) – The hwTriple object defining the base point components of the plane. User can also supply a Python list of three doubles.
  • angle (double) – Angle of rotation.
