Model.hf_ResetDFRibs#
- Model.hf_ResetDFRibs(int_flag)#
- Resets the rib attribute. All the ribs that you modify, dragging the latitude
- lines, are checked with two attribute:
fixed drag
- Parameters:
int_flag (int) – Integer dummy value. Should always be set to 0.
