Model.hf_CreateBinderSectionAndHandles#
- Model.hf_CreateBinderSectionAndHandles(plane_flag, plane_normal, plane_base, node_collection, line_entity, multiple)#
- Creates a section on a binder surface. The section can be identified in
different ways.
- First, it is possible to use a cutting plane. In this case plane_flag is
1 and the cut plane is stored into plane and all the other arguments are ignored.
- Second, it is possible to use two nodes. In this case plane_flag is 0
- and the nodes are stored into node_mark_id,
entity_type is set to nodes, and all the other arguments are ignored.
- Finally, it is possible to select a line. In this case plane_flag is 0
and the line is identified by line_id while all the other arguments are ignored.
- Parameters:
plane_flag (int) – nan
plane_normal (hwTriple) – The hwTriple object defining the plane normal components. User can also supply a Python list of three doubles.
plane_base (hwTriple) – The hwTriple object defining the base point components of the plane. User can also supply a Python list of three doubles.
node_collection (Collection) – The collection containing the entities.
line_entity (Entity) – The object describing the entity.
multiple (int) – nan
