Model.UpdateBinderSections#
- Model.UpdateBinderSections(collection_1, collection_2, collection_3, collection_4, plane_normal, plane_base, rotate_flag, blend_flag, method_flag, sym_flag, con_flag)#
Updates the binder shape using the current section.
- Parameters:
collection_1 (Collection) – The collection containing the surface entities.
collection_2 (Collection) – The collection containing the node entities.
collection_3 (Collection) – The collection containing the line entities.
collection_4 (Collection) – The collection containing the node entities
plane_normal (hwTriple) – The hwTriple object defining the plane normal components. User can also supply a Python list of three doubles.
plane_base (hwTriple) – The hwTriple object defining the base point components of the plane. User can also supply a Python list of three doubles.
rotate_flag (int) – Must be set to 1.
blend_flag (int) – Must be set to 0.
method_flag (int) – Must be set to 5.
sym_flag (int) – Reserved for future development
con_flag (int) – Must be set to 1.
Example#
Update the binder shape use the plane with normal vector [ 1.0 , 0.0 , 0.0 ] and base point [ 0.0 , 0.0 , 0.0 ]#import hm import hm.entities as ent model = hm.Model() # Creating a collection that contains the surface entities surface_collection = hm.CollectionByInteractiveSelection(model, ent.Surface) # Creating a collection that contains the node entities node_collection_1 = hm.CollectionByInteractiveSelection(model, ent.Node) # Creating a collection that contains the line entities line_collection = hm.CollectionByInteractiveSelection(model, ent.Line) # Creating a collection that contains the node entities node_collection_2 = hm.CollectionByInteractiveSelection(model, ent.Node) model.UpdateBinderSections( collection_1=surface_collection, collection_2=node_collection_1, collection_3=line_collection, collection_4=node_collection_2, plane_normal=[1.0, 0.0, 0.0], plane_base=[0.0, 0.0, 0.0], rotate_flag=1, blend_flag=0, method_flag=5, con_flag=1, )
