Model.GetLatitudeLineHandles#
Model.GetLatitudeLineHandles(collection1, collection2, selection_type)#
Finds and shows in HyperMesh the handles of latitude lines stored into collection1.
Parameters:
  • collection1 (Collection) – The collection containing the entities. Valid entities are only lines.
  • collection2 (Collection) – The collection containing the entities. Valid entities are only lines.
  • selection_type (int) –
    Selection type for latitude lines. Valid values are:
    1 - For single latitude lines selection.
    2 - For group latitude lines selection.
Note
Valid entity_type1 value for latitude lines is LINES, and valid selection_type value is 1. If you want to see the handles of a latitude lines group, you need to select two ribs that are stored into mark_id2. Valid entity_type2 value for ribs is LINES and valid selection_type value is 2.
