Model.CE_FE_RegisterAdvanced#
- Model.CE_FE_RegisterAdvanced(integer_array)#
Registers pre-existing FE to multiple connector IDs. Successfully registering pre-existing FE forces a connector to its realized state.
To use this function, a connector must be in user control mode. Also, note that a single FE entity can be registered with, at most, a single connector. Any FE registered with a given connector is treated as part of that connector’s realization.
- Parameters:
integer_array (EntityList) – The entity list that contains the FE entities (of type entity_type) to be registered with a given connector.
Example#
Register elements with IDs 100 and 101 with connector with ID 10, and elements with IDs 200, 201, and 202 with connector with ID 20.#import hm import hm.entities as ent model = hm.Model() # First, change connectors 10 and 20 to the user control mode: ce = hm.Collection(model, ent.Connector, [10]) model.CE_SetSpecificDetail(connector_collection=ce, detail_type=2, integer_value=1, double_value=0.0) # Then, register the element entities with connector 7: model.CE_FE_RegisterAdvanced( integer_array=[ ent.Element(model, 100), ent.Element(model, 101) ] ) # Finally, turn off user control mode for connectors 10 and 20 (optional): ce = hm.Collection(model, ent.Connector, [10, 20]) model.CE_SetSpecificDetail(connector_collection=ce, detail_type=2, integer_value=0, double_value=0.0)
