Open a File
Open a file.
The directory where file open/save dialogs are opened is saved from the previous
successful dialog operation. For example, if you select a file in
C:\my_files, the next time a file dialog is opened, it will
open in C:\my_files. There are a few exceptions:
- If the dialog is associated to a filename entry box, the directory is taken from the path entered in the entry box, instead of using the saved directory.
- Certain dialogs take you to a directory in the installation where the selection would commonly be made, instead of using the saved directory.
- If the directory is not valid, the file dialog opens in the application start-in directory.
Open a file one of the following ways:
- From the Home tools, Files tool group, click the Open Model tool.
- From the menu bar, select .
- Press Ctrl + O.
- In the Open File dialog, navigate to your working directory and select a file to open.
- Optional: Define any options in the Open Options dialog then click Open.
Tip: Quickly open an .hm file by dragging-and-dropping
it from a file browser into the modeling window.
Tip: To open recently used files, select from the menu bar.
Click
to pin a file to the
list.
