Browsers provide a structured view of model data, which you can use to review, modify, create, and manage
the contents of a model. In addition to visualization, browsers offer features like search, filtering, and sorting,
which enhance your ability to navigate and interact with the model data.
FE geometry is topology on top of mesh, meaning CAD and mesh exist as a single entity. The purpose of FE geometry
is to add vertices, edges, surfaces, and solids on FE models which have no CAD geometry.
Tools and workflows that are dedicated to rapidly creating new parts for specific use cases, or amending existing
parts. The current capabilities are focused on stiffening parts.
Use PhysicsAI to build fast predictive models from CAE data. PhysicsAI can be trained on data with any physics or
remeshing and without design variables.
Explore, organize and manage your personal data, collaborate in teams, and connect to other data sources, such as
corporate PLM systems to access CAD data or publish simulation data.
Restriction: Available in Abaqus, Nastran, and OptiStruct.
For Nastran and OptiStruct, it
creates RBE3 elements for the head and CBUSH element for the body. For Abaqus, it creates DCOUP3D elements for the head and element for
the body. The head elements project and connect to the nodes of the adjoining shell
elements. Figure 1.
Sealing Options
Option
Action
create vector
Create orthogonal
vectors for each CBUSH element created during the sealing
realization. These vectors are used to define the orientations
of the CBUSH elements, which is important to the stiffness
defined in the related PBUSH cards.
