Evaluate and View Results
  1. From the Evaluate tool group, click the Run Analysis tool.
    The Evaluate dialog opens.
  2. Enter a name for the run.
  3. Click Run.
    Result files are saved to the home directory and the Run progress bar appears in the status bar.
  4. Once the run is complete, click the Evaluate icon.
  5. Use the Results Explorer to select the hotspot and review its rate of crack growth.
    Figure 3.
  6. Review the working directory for:
    • Log file: CG_Run.log: highlights the run summary
    • Stress Distribution file: n_1814_HotSpot1_Subcase_1_(Static).txt
    • Crack Growth results: n_1814_HotSpot1.csv
