Define a Hotspot
Defining a Hotspot to which Crack Properties are assigned.
Click the Hotspot tool.
The Hotspot guidebar opens.Figure 2.
Click on the left
icon to open the Hotspot creation options.
Figure 3.
Creation option is set to Manual.Figure 4.
Note: Custom Config file allows user to creating a hotspot at required node and create-assign a system to define the crack direction. The feature requires a configuration file (.txt) linked to a .csv file containing nodal information for system creation using 3 nodes. -
Click on Nodes and select node by ID: 1814 and click on
the
button to create hotspot at selected node.
Open Crack definition options by pressing the
button.
Figure 5.
Figure 6.
