Assign Materials
Create Material with Strain Life and Crack Growth – Total Life properties.
Click the Material tool.
The Assign Material dialog opens. - Activate the checkbox next to the part Base and Fillet.
- Click the My Material tab.
Click
A new material named Mat_EN("n") is created. - Set the Elastic Modulus to 155000.
- Set the Standard Error of Log(elastic strain) (SEe) to 0.0.
- Set the Standard Error of Log(plastic strain) (SEp) to 0.0.
- Switch to Crack Properties and review the default properties.
Click Plot & Save.
Figure 3.
- Right-click on the newly created material and select Add to Assign Material List.
- Click the Assign Material Data tab.
- For Base and Fillet, select Mat_EN("n") from the Material drop-down menu.
Accept the default parameters in the Assign Material Data
tab.
Figure 4.
- Exit the dialog.
