For properties which are applied at the same value to every node in a model, like
global properties, the global hook should be used.
Open the global_inputs folder.
Inside the training_files folder, there are seven
.h3d files named
run__000X_m_1_fillet_cantilever.h3d and seven
.json files named
run__000X_m_1_fillet_cantilever.json. Each
.json file contains exactly two material properties,
Young’s modulus and Poisson ratio with different values. It is necessary to have
consistent labels and number of properties across all the samples.Figure 1. Global Property Inputs
Open HyperMesh.
From the menu bar, click View > Ribbons > PhysicsAI to open the PhysicsAI
ribbon.
Create a new project called global_inputs.
From the
PhysicsAI ribbon, select the Create
Project tool.
The Create
Project dialog opens.
In the Create Project dialog, enter
global_inputs for Project Name.
For Location, click
Choose and select a save location for the
project.
Note: The save location for the
project contains all files created by PhysicsAI,
but the original files used for training do not need to reside in the
project folder.
Click OK.
Copy the global_inputs_hook.py file into the
_hooks folder inside the project folder.
Create a new dataset using all seven samples and name it Beam.
From the
Dataset tool.
Figure 3.
The Create
Dataset dialog opens.
For Dataset Name, enter Beam.
For File System, click and navigate to
the training_files folder.
Note: The E and nu labels are selectable inputs to the training.
Select and transfer all of the
.h3d
files.
Figure 4.
Click OK.
The dataset is extracted
and the Datasets dialog opens.
Click
Close.
Train the model.
From the
PhysicsAI ribbon, select the Train an
ML Model tool.
Figure 5.
The Train
Model dialog opens.
For Model Name, enter Displacement.
For Training Data, verify Beam is
selected.
For Inputs, select cae.coord,
cae.model_data.nu, and
cae.model_data.E.
For Outputs, select Displacement.
Click
Train.
Figure 6. Global Property Inputs
The Model
Training dialog opens.
Tip: Once the status changes to
Running, you can click Show Log view the training
logs.
Test the model.
From the
PhysicsAI ribbon, select the Test ML
Model tool.
Figure 7.
The Test
Model dialog opens.
In the Models area, select Displacement.
In the Datasets area, select Beam and click
OK.
Figure 8.
The Model
Testing dialog opens.
In the Model Testing dialog, select
Displacement, and click Display
File to view the results in the modeling window.
Figure 9.
Close the Model
Testing dialog.
New samples can be generated by copying and renaming one or more training
files. Ensure that the associated .json files are also
present with different values of E and nu while creating the test
dataset.
Once the testing is complete, set the model to active.
Important:Setting a
model as active will checkout a stacking license until the model is
deactivated.
From the
PhysicsAI ribbon, select the Manage ML
Models tool.
Figure 10.
The Model
Click Set Active
Model.
Currently, the
prediction feature for a model is available through the HyperMesh CFD GUI
and in batch mode. The CAD or solver deck to be used for prediction should have an
associated .json file named _predict_inp.json
which should be saved in the _hooks folder.
