Import Trained Model
Import a previously trained model.
From the PhysicsAI ribbon, select the Model
Training tool.
The Model Training dialog opens. -
Click Import Model.
The Import Model dialog opens.
- Enter a name for the model.
Select a model to import by completing one of the following options:
- Click
to browse and
select a model from disk.The trained model file (.psmdl) is mandatory. If the associated log files are in the same directory, the log file can also be used.
- Click
to import a
model from Altair Drive.After authenticating, select the model from the list of available model files visible on Altair Drive.
- Click
- Click OK.
