Subcase Information Entry The
            TSTRU command can be used to assign a temperature set identification
        number to the resulting nodal temperatures of a steady-state heat transfer analysis or the
        last time step of a transient heat transfer analysis.
                            | Argument |
                            Options |
                            Description |
                            | option |
                            <SID> Default = Subcase ID  |
                                        - SID
                                        - This is a temperature set identification number. It may
                                            be referenced from a static analysis subcase, in which
                                            case the resulting nodal temperatures of a steady-state
                                            heat transfer analysis or the last time step of a
                                            transient heat transfer analysis are considered as
                                            applied loads for the static analysis.
            - TSTRU is only valid in a
                    heat transfer subcase.
            - If TSTRU does not
                    explicitly appear in a heat transfer subcase, the Subcase ID is used as the
                    default.
            - A temperature set from a heat transfer
                    analysis will override any temperature set defined by the Bulk Data Entries
                        TEMP or TEMPD.
